A training to acquire strong basis in Python to use it efficiently
Pierre Augier (LEGI), Cyrille Bonamy (LEGI), Eric Maldonado (Irstea), Franck Thollard (ISTerre), Oliver Henriot (GRICAD), Christophe Picard (LJK), Loïc Huder (ISTerre)
There are a lot of very good Python packages for sciences. The fundamental packages are in particular:
With IPython
and Spyder
, Python plus these fundamental scientific packages constitutes a very good alternative to Matlab, that is technically very similar (using the libraries Blas and Lapack). Matlab has a JustInTime (JIT) compiler so that Matlab code is generally faster than Python. However, we will see that Numpy is already quite efficient for standard operations and other Python tools (for example pypy
, cython
, numba
, pythran
, theano
...) can be used to optimize the code to reach the performance of optimized Matlab code.
The advantage of Python over Matlab is its high polyvalency (and nicer syntax) and there are notably several other scientific Python packages (see our notebook pres13_doc_applications.ipynb
Code using numpy
usually starts with the import statement
import numpy as np
NumPy provides the type np.ndarray
. Such array are multidimensionnal sequences of homogeneous elements. They can be created for example with the commands:
# from a list
l = [10.0, 12.5, 15.0, 17.5, 20.0]
np.array(l)
array([10. , 12.5, 15. , 17.5, 20. ])
# fast but the values can be anything
np.empty(4)
array([1.27880790e-316, 0.00000000e+000, 6.91986808e-310, 1.57378525e-316])
# slower than np.empty but the values are all 0.
np.zeros([2, 6])
array([[0., 0., 0., 0., 0., 0.], [0., 0., 0., 0., 0., 0.]])
# multidimensional array
a = np.ones([2, 3, 4])
print(a.shape, a.size, a.dtype)
a
(2, 3, 4) 24 float64
array([[[1., 1., 1., 1.], [1., 1., 1., 1.], [1., 1., 1., 1.]], [[1., 1., 1., 1.], [1., 1., 1., 1.], [1., 1., 1., 1.]]])
# like range but produce 1D numpy array
np.arange(4)
array([0, 1, 2, 3])
# np.arange can produce arrays of floats
np.arange(4.)
array([0., 1., 2., 3.])
# another convenient function to generate 1D arrays
np.linspace(10, 20, 5)
A NumPy array can be easily converted to a Python list.
a = np.linspace(10, 20 ,5)
list(a)
# Or even better
a.tolist()
Beside some convenient functions for the manipulation of data in arrays of arbritrary dimensions, numpy
can be much more efficient than pure Python.
n = 1000
# we use the ipython magic command %timeit
%timeit list(range(n))
15.6 µs ± 1.59 µs per loop (mean ± std. dev. of 7 runs, 10000 loops each)
%%capture timeit_python
# to capture the result of the command timeit in the variable timeit_python
# Pure Python
%%capture timeit_numpy
# numpy
%timeit np.arange(n)
def compute_time_in_second(timeit_result):
string = timeit_result.stdout
print(string)
for line in string.split('\n'):
words = line.split(' ')
if len(words) > 1:
time = float(words[0])
unit = words[1]
if unit == 'ms':
time *= 1e-3
elif unit == 'us':
time *= 1e-6
elif unit == 'ns':
time *= 1e-9
return time
def compare_times(string, timeit_python, timeit_numpy):
time_python = compute_time_in_second(timeit_python)
time_numpy = compute_time_in_second(timeit_numpy)
print(string + ': ratio times (Python / NumPy): ',
time_python/time_numpy)
compare_times('Creation of object', timeit_python, timeit_numpy)
12.7 us +- 1.14 us per loop (mean +- std. dev. of 7 runs, 100000 loops each) 1.31 us +- 112 ns per loop (mean +- std. dev. of 7 runs, 1000000 loops each) Creation of object: ratio times (Python / NumPy): 9.694656488549617
n = 200000
python_r_1 = range(n)
python_r_2 = range(n)
numpy_a_1 = np.arange(n)
numpy_a_2 = np.arange(n)
%%timeit
# Regular Python
[(x + y) for x, y in zip(python_r_1, python_r_2)]
print(timeit_python)
16.6 ms +- 220 us per loop (mean +- std. dev. of 7 runs, 100 loops each)
%%timeit
#Numpy
numpy_a_1 + numpy_a_2
print(timeit_numpy)
246 us +- 16.7 us per loop (mean +- std. dev. of 7 runs, 1000 loops each)
compare_times('Additions', timeit_python, timeit_numpy)
16.6 ms +- 220 us per loop (mean +- std. dev. of 7 runs, 100 loops each) 246 us +- 16.7 us per loop (mean +- std. dev. of 7 runs, 1000 loops each) Additions: ratio times (Python / NumPy): 67.47967479674797
This shows that when you need to perform mathematical operations on a lot of homogeneous numbers, it is more efficient to use numpy
arrays.
A = np.random.random([4, 5])
A
array([[0.89925962, 0.31519992, 0.17170063, 0.06102236, 0.6055506 ], [0.43365108, 0.67461267, 0.34962124, 0.75648088, 0.53096922], [0.65643503, 0.4723704 , 0.77202087, 0.50192904, 0.14067726], [0.80709755, 0.2314217 , 0.65465368, 0.28459125, 0.54727527]])
# Get the element from second line, first column
A[1, 0]
0.4336510750584107
# Get the first two lines
A[:2]
array([[0.89925962, 0.31519992, 0.17170063, 0.06102236, 0.6055506 ], [0.43365108, 0.67461267, 0.34962124, 0.75648088, 0.53096922]])
# Get the last column
A[:, -1]
array([0.6055506 , 0.53096922, 0.14067726, 0.54727527])
# Get the first two lines and the columns with an even index
A[:2, ::2]
array([[0.89925962, 0.17170063, 0.6055506 ], [0.43365108, 0.34962124, 0.53096922]])
cond = A > 0.5
print(cond)
print(A[cond])
[[ True False False False True] [False True False True True] [ True False True True False] [ True False True False True]] [0.89925962 0.6055506 0.67461267 0.75648088 0.53096922 0.65643503 0.77202087 0.50192904 0.80709755 0.65465368 0.54727527]
The mask is in fact a particular case of the advanced indexing capabilities provided by NumPy. For example, it is even possible to use lists for indexing:
# Selecting only particular columns
print(A)
A[:, [0, 1, 4]]
[[0.89925962 0.31519992 0.17170063 0.06102236 0.6055506 ] [0.43365108 0.67461267 0.34962124 0.75648088 0.53096922] [0.65643503 0.4723704 0.77202087 0.50192904 0.14067726] [0.80709755 0.2314217 0.65465368 0.28459125 0.54727527]]
array([[0.89925962, 0.31519992, 0.6055506 ], [0.43365108, 0.67461267, 0.53096922], [0.65643503, 0.4723704 , 0.14067726], [0.80709755, 0.2314217 , 0.54727527]])
(A+5)**2
array([[34.80126403, 28.25135024, 26.7464874 , 25.61394735, 31.42219749], [29.52456401, 32.20122896, 28.61844741, 33.13707212, 30.59162046], [31.99525724, 29.94683782, 33.31622493, 30.27122313, 26.42656267], [33.72238198, 27.36777304, 31.97510827, 27.92690466, 30.77226288]])
np.exp(A) # With numpy arrays, use the functions from numpy !
array([[2.45778274, 1.37053329, 1.18732233, 1.06292268, 1.83226077], [1.54288042, 1.9632724 , 1.41853016, 2.13076459, 1.70057974], [1.92790714, 1.60379132, 2.16413527, 1.65190478, 1.15105309], [2.24139301, 1.26039064, 1.92447592, 1.3292186 , 1.72853679]])
A[:, 0] = 0.
print(A)
[[0. 0.31519992 0.17170063 0.06102236 0.6055506 ] [0. 0.67461267 0.34962124 0.75648088 0.53096922] [0. 0.4723704 0.77202087 0.50192904 0.14067726] [0. 0.2314217 0.65465368 0.28459125 0.54727527]]
# BONUS: Safe element-wise inverse with masks
cond = (A != 0)
A[cond] = 1./A[cond]
print(A)
[[ 0. 3.17258959 5.82409047 16.387435 1.65138967] [ 0. 1.48233207 2.86023812 1.32191048 1.88334836] [ 0. 2.11698277 1.29530177 1.99231351 7.10846954] [ 0. 4.32111589 1.5275252 3.51381149 1.82723405]]
print([s for s in dir(A) if not s.startswith('__')])
['T', 'all', 'any', 'argmax', 'argmin', 'argpartition', 'argsort', 'astype', 'base', 'byteswap', 'choose', 'clip', 'compress', 'conj', 'conjugate', 'copy', 'ctypes', 'cumprod', 'cumsum', 'data', 'diagonal', 'dot', 'dtype', 'dump', 'dumps', 'fill', 'flags', 'flat', 'flatten', 'getfield', 'imag', 'item', 'itemset', 'itemsize', 'max', 'mean', 'min', 'nbytes', 'ndim', 'newbyteorder', 'nonzero', 'partition', 'prod', 'ptp', 'put', 'ravel', 'real', 'repeat', 'reshape', 'resize', 'round', 'searchsorted', 'setfield', 'setflags', 'shape', 'size', 'sort', 'squeeze', 'std', 'strides', 'sum', 'swapaxes', 'take', 'tobytes', 'tofile', 'tolist', 'tostring', 'trace', 'transpose', 'var', 'view']
# Ex1: Get the mean through different dimensions
print(A)
print('Mean value', A.mean())
print('Mean line', A.mean(axis=0))
print('Mean column', A.mean(axis=1))
[[ 0. 3.17258959 5.82409047 16.387435 1.65138967] [ 0. 1.48233207 2.86023812 1.32191048 1.88334836] [ 0. 2.11698277 1.29530177 1.99231351 7.10846954] [ 0. 4.32111589 1.5275252 3.51381149 1.82723405]] Mean value 2.9143043986324475 Mean line [0. 2.77325508 2.87678889 5.80386762 3.1176104 ] Mean column [5.40710095 1.50956581 2.50261352 2.23793733]
# Ex2: Convert a 2D array in 1D keeping all elements
print(A, A.shape)
A_flat = A.flatten()
print(A_flat, A_flat.shape)
[[ 0. 3.17258959 5.82409047 16.387435 1.65138967] [ 0. 1.48233207 2.86023812 1.32191048 1.88334836] [ 0. 2.11698277 1.29530177 1.99231351 7.10846954] [ 0. 4.32111589 1.5275252 3.51381149 1.82723405]] (4, 5) [ 0. 3.17258959 5.82409047 16.387435 1.65138967 0. 1.48233207 2.86023812 1.32191048 1.88334836 0. 2.11698277 1.29530177 1.99231351 7.10846954 0. 4.32111589 1.5275252 3.51381149 1.82723405] (20,)
b = np.linspace(0, 10, 11)
c = b @ b
# before 3.5:
# c = b.dot(b)
print(b)
print(c)
[ 0. 1. 2. 3. 4. 5. 6. 7. 8. 9. 10.] 385.0
Matlab | Numpy |
element wise | .* |
dot product | * |
dtypes
and sub-packages¶numpy
arrays can also be sorted, even when they are composed of complex data if the type of the columns are explicitly stated with dtypes
dtypes = np.dtype([('country', 'S20'), ('density', 'i4'),
('area', 'i4'), ('population', 'i4')])
x = np.array([('Netherlands', 393, 41526, 16928800),
('Belgium', 337, 30510, 11007020),
('United Kingdom', 256, 243610, 62262000),
('Germany', 233, 357021, 81799600)],
dtype=dtypes)
arr = np.array(x, dtype=dtypes)
arr.sort(order='density')
print(arr)
[(b'Germany', 233, 357021, 81799600) (b'United Kingdom', 256, 243610, 62262000) (b'Belgium', 337, 30510, 11007020) (b'Netherlands', 393, 41526, 16928800)]
In the previous example, we manipulated a one dimensional array containing quadruplets of data. This functionality can be used to load images into arrays and save arrays to images.
It can also be used when loading data of different types from a file with np.genfromtxt
We already saw numpy.random
to generate numpy
arrays filled with random values. This submodule also provides functions related to distributions (Poisson, gaussian, etc.) and permutations.
To perform linear algebra with dense matrices, we can use the submodule numpy.linalg
. For instance, in order to compute the determinant of a random matrix, we use the method det
A = np.random.random([5,5])
print(A)
np.linalg.det(A)
[[0.47138506 0.41353868 0.09441948 0.225147 0.82335198] [0.04490952 0.14682972 0.31792846 0.22918746 0.73823443] [0.50485749 0.99705961 0.51896582 0.93318595 0.11375617] [0.37148317 0.0477689 0.29061475 0.41826056 0.47950005] [0.70324502 0.82838271 0.92172528 0.79532669 0.56698101]]
0.06968780805887545
squared_subA = A[1:3, 1:3]
print(squared_subA)
np.linalg.inv(squared_subA)
[[0.14682972 0.31792846] [0.99705961 0.51896582]]
array([[-2.15522717, 1.32033369], [ 4.14071576, -0.6097731 ]])
If the data are sparse matrices, instead of using numpy
, it is recommended to use scipy
from scipy.sparse import csr_matrix
print(csr_matrix([[1, 2, 0], [0, 0, 3], [4, 0, 5]]))
(0, 0) 1 (0, 1) 2 (1, 2) 3 (2, 0) 4 (2, 2) 5
scipy
also provides a submodule for linear algebra scipy.linalg
. It provides an extension of numpy.linalg
For more info, see the related FAQ entry: https://www.scipy.org/scipylib/faq.html#why-both-numpy-linalg-and-scipy-linalg-what-s-the-difference.
Broadcasting is the name given to the method that NumPy uses to allow array arithmetic between arrays with a different shape or size.
Although the technique was developed for NumPy, it has also been adopted more broadly in other numerical computational libraries, such as Theano, TensorFlow, and Octave.
Broadcasting solves the problem of arithmetic between arrays of differing shapes by in effect replicating the smaller array along the last mismatched dimension.
The term broadcasting describes how numpy treats arrays with different shapes during arithmetic operations. Subject to certain constraints, the smaller array is “broadcast” across the larger array so that they have compatible shapes.
— Broadcasting, SciPy.org
See : https://docs.scipy.org/doc/numpy-1.13.0/user/basics.broadcasting.html
# scalar and one-dimensional
a = np.array([1, 2, 3])
print(a)
b = 2
print(b)
c = a + b
print(c)
[1 2 3] 2 [3 4 5]
# scalar and two-dimensional
A = np.array([[1, 2, 3], [1, 2, 3]])
print(A)
b = 2
print(b)
C = A + b
print(C)
[[1 2 3] [1 2 3]] 2 [[3 4 5] [3 4 5]]
# one-dimensional and two-dimensional
print(A)
b = np.array([1, 2, 3])
print(b)
C = A + b
print(C)
[[1 2 3] [1 2 3]] [1 2 3] [[2 4 6] [2 4 6]]
Broadcasting is a handy shortcut that proves very useful in practice when working with NumPy arrays.
That being said, it does not work for all cases, and in fact imposes a strict rule that must be satisfied for broadcasting to be performed.
Arithmetic, including broadcasting, can only be performed when the shape of each dimension in the arrays are equal or one has the dimension size of 1. The dimensions are considered in reverse order, starting with the trailing dimension; for example, looking at columns before rows in a two-dimensional case.
# Vetorize a function
def myfunc(a, b):
"Return a-b if a>b, otherwise return a+b"
if a > b:
return a - b
else:
return a + b
vfunc = np.vectorize(myfunc)
vfunc([1, 2, 3, 4], 2)
array([3, 4, 1, 2])
# Vectorize a problem
def dist_loop(X,Y):
Naive loop
res=0
for x,y in zip(X,Y):
res += (x-y)**2
return np.sqrt(res)
def dist(x,y):
return np.sqrt(np.sum((x-y)**2))
a = np.random.random(1000)
b = np.random.random(1000)
%time dist_a_b = dist(a,b)
%time dist_a_b_loop = dist_loop(a,b)
assert np.isclose(dist_a_b, dist_a_b_loop)
CPU times: user 95 µs, sys: 0 ns, total: 95 µs Wall time: 78.7 µs CPU times: user 619 µs, sys: 0 ns, total: 619 µs Wall time: 608 µs
